Sinumerik Alarm 10948 Channel %1 block %2 curve table %3: position jump at end of period
%3 = Number of curve table
A periodic curve table was defined in which the position of the following axis at the end of the table was different to the position at the start of the table.
Correct the part program and start it again.
