Sinumerik Alarm 10955 Channel %1 block %2 curve table %3: missing master axis motion
%3 = Number of curve table
A slave axis motion has been programmed without a master axis motion. This can also occur if, with active radius compensation, a block is created in which the slave axis moves but not the master axis. The alarm is for information only and can be suppressed by setting MD $MC_CTAB_ENABLE_NO_LEADMOTION = 2.
Alarm can be switched off via MD $MC_CTAB_ENABLE_NO_LEADMOTION = 2.
