Sinumerik Alarm 10956 Channel %1 block %2 curve table %3: NC memory limit DRAM reached
%3 = Number of curve table
Insufficient memory in the DRAM while defining the curve table.
Delete the curve tables that are no longer required in the DRAM or reconfigure the memory space for the curve tables. The curve table must then be redefined. Machine data for memory configuration of the curve tables in DRAM: MN_MM_NUM_CURVE_TABS_DRAM, MN_MM_NUM_CURVE_SEGMENTS_DRAM, MN_MM_NUM_CURVE_POLYNOMS_DRAM.
