Sinumerik Alarm 10961 Channel %1 block %2 maximum cubic polynomials are allowed on active radius compensation.
With active radius compensation, only up to cubic polynomials are permissible for the geometry axes. In this case no 4th or 5th degree polynomials can be programmed.
– Local alarm reaction.
Modify part program.
