Sinumerik Alarm 10962 Channel %1 block %2 function %3 not possible with path correction
%3 = Function name
With this software release, the specified function can not yet be used together with tool radius compensation. Please modify the part program or obtain a higher software version.
– Local alarm reaction.
Modify part program.
