Sinumerik Alarm 12050 Channel %1 block %2 DIN address %3 not configured
%3 = DIN address in the source text block
The name of the DIN address (e.g. X, U, X1) is not defined in the control. In addition to the fixed DIN addresses, the control also has variable addresses. Refer to “Variable addresses” in the Programming Guide. The names of these addresses can be altered by machine data. e.g.: DIN identifier -> Configured identifier G01 -> LINE, G04 -> WAIT …
– Correction block
Study the Programming Guide and the machine data with respect to the addresses actually configured and their significance and correct the DIN block accordingly.
