Sinumerik Alarm 12080 Channel %1 block %2 syntax error in text %3
%3 = Source text area
At the text position shown, the grammar in the block is incorrect. The precise reason for this error cannot be specified in more detail because there are too many possibilities.
Example 1:
N10 IF GOTOF … ; the condition for the jump is missing!
Example 2:
N10 DEF INT VARI=5
N11 X VARI ; the operation is missing for the X and VARI variables
– Correction block
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block. Analyze the block and correct it in accordance with the syntax rules given in the Programming Guide.
