Sinumerik Alarm 12120 Channel %1 block %2 G function not separately programmed
The G function programmed in this block must be alone in the block. No general addresses or synchronous actions may occur in the same block. These G functions are:
G25, G26: Working area and spindle speed limitation
G110, G111, G112: Pole programming with polar coordinates
G92: Spindle speed limitation with v constant
STARTFIFO, STOPFIFO: Control of preprocessing buffer
E.g. G4 F1000 M100: no M function allowed in the G4 block.
– Correction block
Program G function by itself in the block.
