Sinumerik Alarm 12140 Channel %1 block %2 functionality %3 not implemented
%3 = Software construct in the source text
In the full configuration of the control functions are possible that are not yet implemented in the current version.
– Correction block
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block. The displayed function must be removed from the program.
