Sinumerik Alarm 12190 Channel %1 block %2 variable of type ARRAY has too many dimensions
Array with variables of type STRING may be no more than 1-dimensional, and with all other variables no more than 2-dimensional.
– Correction block
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block. Correct the array definition, with multi-dimensional arrays define a second 2-dimensional array if necessary and operate it with the same field index.
