Sinumerik Alarm 12200 Channel %1 block %2 symbol %3 cannot be created
%3 = Symbol in the source block
The symbol to be created with the DEF instruction cannot be created because:
• it has already been defined (e.g. as variable or function)
• the internal memory location is no longer sufficient (e.g. with large arrays)
– Correction block
Make the following checks:
• Check with the text editor whether the name to be allocated in the active program cycle (main program and called sub programs) has already been used.
• Estimate the memory requirements for the symbols already defined and reduce these if necessary by using fewer global and more local variables.
