Sinumerik Alarm 12310 Channel %1 block %2 axis parameter missing on procedure call %3
%3 = Source string
When calling the subroutine, an AXIS parameter is missing which, according to the EXTERN declaration, should be present. With the EXTERN instruction, user-defined subroutines (procedures) are made “known” that have a parameter transfer. Procedures without parameter transfer require no EXTERN declaration.
Example:
Subroutine XYZ (with the formal parameters):
PROC XYZ (INT X, VAR INT Y, AXIS A, AXIS B)
EXTERN instruction (with variable types):
EXTERN XYZ (INT, VAR INT, AXIS, AXIS) Subroutine call (with actual parameters):
N10 XYZ (, Y1, R_TABLE)
Variable X is defaulted with value 0
Variable Y is supplied with the value of the variable Y1 and returns the results to the calling program after the subroutine run
Variable A is supplied with the axis in R_TABLE
Variable B missing!
– Correction block
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block. Program the missing AXIS parameter in the call.
