Sinumerik Alarm 12360 Channel %1 block %2 dimension of parameter %3 incorrect
%3 = Source string
The following possibilities of error must be checked:
• The current parameter is an array, but the formal parameter is a variable
• The current parameter is a variable, but the formal parameter is an array
• The current and formal parameters are arrays, but not with the dimensions to be defined.
– Correction block
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block. Correct the NC part program in accordance with the cause of error as listed above.
