Sinumerik Alarm 12430 Channel %1 block %2 specified index is invalid
In specifying an array index (in the array definition) an index was used that is outside the permissible range.
– Correction block
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block. Specify array index within the permissible range. Value range per array dimension: 1 – 32 767.
