Sinumerik Alarm 12475 Channel %1 block %2 invalid G function number %3 programmed
%3 = G code number
A non-allowed G function number (parameter 3) has been programmed for a G group with indirect G code programming. Only the G function numbers indicated in the Programming Guide “Fundamentals”, Section 12.3 “List of G functions/Path conditions” are allowed.
Modify part program.
