Sinumerik Alarm 12520 Channel %1 block %2 too many tool parameters %3
%3 = Source symbol
In the part program, in the tool offset file (…_TOA) and in the initialization file (…_INI), no more than 5 tool offset parameters may be used per block.Example:
N …
N 100 $TC_DP1 [5,1] = 130, $TC_DP3 [5,1] = 150.123,
$TC_DP4 [5,1] = 223.4, $TC_DP5 [5,1] = 200.12,
$TC_DP6 [5,1] = 55.02
N …
– Correction block
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block.
• Divide up the part program block into several blocks.
• If necessary, use the local variable for storing intermediate results.
