Sinumerik Alarm 12540 Channel %1 block %2 Block is too long or too complex
The maximum internal block length after translator processing must not exceed 256 characters. After editing, for example, several macros in the block or a multiple nesting, this limit can be exceeded.
– Correction block
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block. Divide up the program block into several sub blocks.
