Sinumerik Alarm 12552 Channel %1 block %2 tool/magazine OEM parameter not defined. Option not set.Option not set.
The programmed $TC_… Cx system parameter is not known in the control.
• Correct the name used (writing error)
• $TC_DPCx, $TC_TPCx, $TC_MOPCx, $TC_MAPCx, $TC_MPPCx, $TC_DPCSx,$TC_TPCSx, $TC_MOPCSx, $TC_MAPCSx, $TC_MPPCSx; with x=1,…10
• These are the OEM parameters of the tools magazines, The corresponding machine data value is set to < 10, or the option ‘TM OEM parameters’ has not been set.
• Use correct parameter number, or – if the name cannot be changed – set machine data correction (see $MN_MM_NUM_CC_TOA_PARAM, …$MN_MM_NUM_CCS_TOA_PARAM, …). )
• Check the option (machine data are only effective when the option is enabled).
