Sinumerik Alarm 12584 Channel %1 block %2 variable %3 cannot be read synchronously with motion
%3 = Source symbol
In motion synchronous actions on the left side of the compare operation, only special variables are allowed as input variables of SYNFCT and as input variables for PUTFTOCF. Motion synchronous access is possible here. Example:
PUTFTOCF(1, $AA_OVR, 2, 1, 2) The variable $AA_OVR is not allowed here.
Modify part program. For the functions SYNFCT and PUTFTOCF only certain variables are allowed, for example $AC_DTGPW.
