Sinumerik Alarm 12620 Channel %1 block %2 accessing this variable as single character not possible
%3 = Source string
The variable is not a user-defined variable. The single character access is only allowed for user-defined variables (LUD/GUD).
– Correction block
Temporarily store variable in user-defined STRING, process this and put back into storage.
