Sinumerik Alarm 12630 Channel %1 block %2 skip ID/label in control structure not allowed
%2 = Block number
Blocks with control structures (FOR, ENDIF, etc.) cannot be concealed and must not contain any labels.
– Correction block
Modify part program: Reproduce skip ID via an IF query. Write the label alone in the block before the control structure block.
