Sinumerik Alarm 12660 Channel %1 block %2 motion synchronous action: variable %3 reserved for motion synchronous actions and technology cycles
%2 = Block number
%3 = Variable name
The displayed variable may only be used in motion synchronous actions or in technology cycles. For example, ‘$R1’ may only be used in motion synchronous actions. In standard part programs R parameters are programmed with R1.
– Correction block
Modify part program.
