Sinumerik Alarm 12724 Channel %1 block %2 no radius programmed for cylinder interpolation activation/deactivation
When programming G07.1 (cylinder interpolation TRACYL), no cylinder radius has been programmed. Selection of the cylinder interpolation (TRACYL) with G07.1 C deselect with G07.1 C0. For “C” the name of the rotary axis defined in the TRACYL machine data has to be programmed.
– Correction block
G07.1 block, program the cylinder radius under the name of the rotary axis for the cylinder interpolation.
