Sinumerik Alarm 12726 Channel %1 block %2 illegal plane selection with parallel axes
In a block with plane selection (G17 – G19), a basic axis of the coordinate system must not be programmed together with the parallel axis assigned to it.
– Correction block
For plane selection with G17, G18, G19 either program the basic axis of the coordinate system or the assigned parallel axis.
