Sinumerik Alarm 12728 Channel %1 block %2 distance for double turret not set
The tool clearance for the double turret head in the setting data $SC_EXTERN_DOUBLE_TURRET_DIST is 0.
– Correction block
Enter tool clearance for the double turret head in the setting data $SC_EXTERN_DOUBLE_TURRET_DIST.
