Sinumerik Alarm 14000 Channel %1 block %2 illegal end of file
Part program was not terminated with M30, M02 or M17. This error is also signalled at the host if the environment variables NCPROG or NCUPROG have been set to a non-existing file.
End part program with M30, M02 or M17 and start part program. Check environment variables NCPROG and NCUPROG at the host.
