Sinumerik Alarm 14001 Channel %1 block %2 illegal end of block
After system-internal data manipulation (e.g. when transferring blocks from an external source) a sub file can end without having LF as the last character.
Read out the part program, modify it with a text editor (e.g., insert blanks or comments before the displayed block), so that after reading it in again the part program has a different structure in the memory.
