Sinumerik Alarm 14009 Channel %1 block %2 illegal program path %3
%3 = Program path
The part program command CALLPATH was called with a parameter (program path) referring to a directory which does not exist in the file system of the NCK.
• Modify the CALLPATH instruction such that the parameter contains the complete path name of the loaded directory.
• Load the programmed directory in the file system of the NCK.
