Sinumerik Alarm 14014 Channel %1 selected program %3 not available or will be edited
%3 = Program name
The selected part program is not in the NCK memory or the access authorization for the program selection is from a higher level than the current control status. During creation, this program received the protection level of the NC control which was active at the time.As of SW 5, when a program is edited on the MMC, it can no longer be started with NC Start.
Reload the program in the NCK memory or check and correct the name of the directory (workpiece overview) and the program (program overview) and reselect.
