Sinumerik Alarm 14020 Channel %1 block %2 wrong value or wrong number of parameters on function or procedure call
• An illegal parameter value was specified in a function or procedure call.
• An illegal number of actual parameters was programmed in a function or procedure call.
Modify part program.
