Sinumerik Alarm 14026 Channel %1 block %2 motion synchronous action: invalid polynomial number in the FCTDEF command
An FCTDEF command was programmed with a polynomial number that exceeds the maximum value set in $MC_MM_NUM_FCTDEF_ELEMENTS.
Modify part program.
