Sinumerik Alarm 14034 Channel %1 block %2 involute: angle of rotation too large
With programming of the angle of rotation (with AR) for involute interpolation, the maxi- mum programmable angle of rotation is limited if the involute is moving towards the basic circle. The maximum value is reached if the involute touches the basic circle. With MD_INVOLUTE AUTO_ANGLE_RESTRICTION = TRUE, each angle is accepted without an alarm; if necessary, the angle is automatically limited during interpolation.
Modify part program.
