Sinumerik Alarm 14039 Channel %1 block %2 involute: end point programmed several times
With involute interpolation, either the end point with the geometry axis identifiers or the angle of rotation with AR=value can be programmed. Simultaneous programming of end point and angle of rotation in one block is not allowed, since the end point can thus not be defined exactly.
Modify part program.
