Sinumerik Alarm 14051 Channel %1 block %2 arithmetic error in part program
• In calculating an arithmetic expression, an overflow has occurred (e.g. division by zero)
• In a data type, the representable value range has been exceeded
Analyze the program and correct the defective point in the program.
