Sinumerik Alarm 14060 Channel %1 block %2 invalid skip level with differential block skip
With “Differential block skip”, a skip level greater than 7 has been specified. (In packet 1 specification of a value for the skip level is rejected by the converter as a syntax error, i.e. the only possibility is a “Suppress block” ON/OFF on one level).
Enter a skip level (number behind the slash) less than 8.
