Sinumerik Alarm 14070 Channel %1 block %2 memory for variables not sufficient for subroutine call
A called subroutine cannot be processed (opened), either because the internal data memory to be created for general purposes is not large enough, or because the available memory for the local program variables is too small. The alarm can only occur in MDA mode.
Analyze the part program section:
1. Has the most useful data type always been selected in the variable definitions? (For example REAL for data bits is poor; BOOL would be better)
2. Can local variables be replaced by global variables?
