Sinumerik Alarm 14082 Channel %1 block %2 label %3 program section not found
%3 = Start or end label
The start point for repetition of the program part with CALL BLOCK TO has not been found or the same program part repetition has been called recursively.
Check the start and end labels for programming repetition in the user program.
