Sinumerik Alarm 14088 Channel %1 block %2 axis %3 doubtful position
An axis position larger than 3.40e+38 increments has been programmed. This alarm can be suppressed with bit 11 in $MN_SUPPRESS_ALARM_MASK.
Modify part program.
