Sinumerik Alarm 14090 Channel %1 block %2 illegal D number
A value less than zero has been programmed under address D. A set of parameters with 25 correction values has been automatically assigned to each active tool. Each tool can have 9 sets of parameters (D1 – D9, initial setting is D1). When the D number changes, the new parameter set is active (D0 is used for deselecting the correction values).
N10 G.. X… Y… T15 ; Parameter set D1 of T15 active
N50 G.. X… D3 M.. ; Parameter set D3 of T15 active
N60 G.. X.. T20 ; Parameter set D1 of T20 active
Program D numbers in the permissible value range (D0, D1 to D9).
