Sinumerik Alarm 14093 Channel %1 block %2 path interval <= 0 with polynominal interpolation
In the polynomial interpolation POLY, a negative value or zero has been programmed under the keyword for the polynomial length PL=…
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block. Correct the value given in PL = …
