Sinumerik Alarm 14096 Channel %1 block %2 illegal type conversion
During the program run, a variable value assignment or an arithmetic operation has caused data to be processed in such a way that they have to be converted to another type. This would lead to the value range being exceeded.Value ranges of the various variable types:
• REAL: Property: Fractional number with dec. pt., value range: +/-(2-1022-2+1023)
• INT: Property: Integers with signs, value range: +/-(231-1)
• BOOL: Property: Truth value TRUE, FALSE, value range: 0,1
• CHAR: Property: 1 ASCII character, value range: 0-255
• STRING: Property: Character string (max. 100 values), value range: 0-255
• AXIS: Property: Axis addresses, value range: Axis names only
• FRAME: Property: Geometric information, value range: As for axis paths Overview of type conversions:
• from REAL to: REAL: yes, INT: yes*, BOOL: yes1), CHAR: yes*, STRING: -, AXIS: -, FRAME:
•from INT to: REAL: yes, INT: yes, BOOL: yes1), CHAR: if value 0 …255, STRING: -, AXIS: -, FRAME:
•from BOOL to: REAL: yes, INT: yes, BOOL: yes, CHAR: yes, STRING: -, AXIS: -, FRAME:
•from CHAR to: REAL: yes, INT: yes, BOOL: yes1), CHAR: yes, STRING: yes, AXIS: -, FRAME:
•from STRING to: REAL: -, INT: -, BOOL: yes2), CHAR: only if 1 character, STRING: yes, AXIS: -, FRAME:
•from AXIS to: REAL: -, INT: -, BOOL: -, CHAR: -, STRING: -, AXIS: yes, FRAME:
•from FRAME to: REAL: -, INT: -, BOOL: -, CHAR: -, STRING: -, AXIS: -, FRAME: yes
1) Value 0 corresponds to TRUE, value ==0 corresponds to FALSE.
2) String length 0 => FALSE, otherwise TRUE.
3) If only one character.It is not possible to convert from type AXIS and FRAME nor into type AXIS and FRAME.
Modify the program section such that the value range is not exceeded, e.g. by a modified variable definition.
