Sinumerik Alarm 14099 Channel %1 block %2 result in string concatenation too long
The result of string chaining returns a string which is greater than the maximum string length laid down by the system.
Adapt part program. With the function STRLEN, it is also possible to test the size of the sum string before performing the chaining operation.
