Sinumerik Alarm 14100 Channel %1 block %2 orientation transformation not available
Four transformation groupings (transformation types) can be set for each channel via machine data. If the keyword TRAORI(n) (n … number of the transformation grouping) is used to address a transformation grouping for which the machine data is not defaulted, the alarm message will be triggered.
Press the NC Stop key and select the function “Correction block” with the soft key PROGRAM CORRECT. The correction pointer positions on the incorrect block.
• Check the number of the transformation grouping when calling the part program with the keyword TRAORI(n) (n … number of the transformation grouping).
• Enter the machine data for this transformation grouping and then activate by “Power On”.
