Sinumerik Alarm 14110 Channel %1 block %2 Euler angles and orientation vector components programmed
An orientation has been programmed with Euler angles and the component of an orientation vector at the same time.
Example:
N50 TRAORI (1)
N55 A2=10 B2=20 C3=50 ; alarm, because Euler angle and orientation vector
Program only one type, in other words when transformation is switched on program either Euler angles only or orientation vectors (direction vectors) only.
