Sinumerik Alarm 14116 Channel %1 block %2 absolute orientation programmed while ORIPATH is active
The orientation has been entered as an absolute value (e.g. by a direction vector) although ORIPATH is active. When ORIPATH is active, the orientation is determined from the leading and sidewards angles relative to the path tangent and surface normal.
Modify part program.
