Sinumerik Alarm 14117 Channel %1 block %2 no angle or direction of the cone programmed
With taper circumference interpolation of orientation (ORICONCW and ORICONCC), either the opening angle or the direction vector of the taper must be programmed. Otherwise, the change of orientation is not clearly defined.
Modify part program.
