Sinumerik Alarm 14123 Channel %1 block %2 nutation angle of the cone too small
With taper circumference interpolation, the programmed opening angle of the taper must be greater than the half of the angle between the start and end orientation. Otherwise, a taper cannot be defined.
Modify part program.
