Sinumerik Alarm 14134 Channel %1 block %2 G code for orientation interpolation not allowed
It is only possible to program a G code of the 51st G code group if machine data ORI_DEF_WITH_G_CODE or ORI_IPO_WITH_G_CODE is set to TRUE.
Adapt machine data.
