Sinumerik Alarm 14150 Channel %1 block %2 illegal tool carrier number programmed or declared (MD)
A tool holder number was programmed which is negative or greater than the machine data MC_MM_NUM_TOOL_CARRIER.
Please inform the authorized personnel/service department. Program valid tool holder number or adapt machine data MC_MM_NUM_TOOL_CARRIER.
