Sinumerik Alarm 14151 Channel %1 block %2 illegal tool carrier rotation
A toolholder was activated with an angle of rotation unequal to zero, although the associated axis is not defined. A rotary axis is not defined when all three direction components are zero.
Set angle of rotation to zero, or define the associated rotary axis.
